If the Panasonic ram disc is brand new, and totally clean (free of smudge marks, no scratches), than it should work. If you have tried over and over again with the same result, than there is definitely something wrong with the recorder.
I hope you returned the unit in time to get your money back. If not, raise a stink and ask for managers until they give you the money back.
By the way, I personally use a brand of dvd-r called "Taiyo Yuden". I buy them at Supermediastore or shop4tech. The brand is supposed to be the creator of cd-r's. They are top quality. If you research it you'll find out that a lot of times different brands actually use different manufacturers. Sometimes one brand can actually use two different manufacturers. Usually the quality from these brands are Medium. The one exception is Verbatim which I think actually uses Taiyo Yuden discs. It's often cheaper to buy the Taiyo Yudens from one of those two stores than it it to buy a brand at an actual store.
Results 91 to 91 of 91
How long is your video collection? Days, weeks, months years, decades?
By yoda313 in forum Off topicReplies: 12Last Post: 1st Jan 2012, 08:10 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 07:05 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
My PC will not recognise my MP3- It was fine for 8 months??!
By jenniewb in forum ComputerReplies: 8Last Post: 28th Dec 2008, 12:30 -
How do you keep your computer cool in the hot months?
By yoda313 in forum PollsReplies: 44Last Post: 20th Jul 2008, 08:21
