well it just doesnt get any better. I received the pioneer dvr 310 from newegg. I hooked it up and guess what? NO VIDEO. audio works fine. I checked the s video cable and it works. I called pioneer and talked to the tech. He had me reset the machine but that still did not work. He told me its about 3 years old and probably defective. I couldnt believe I bought a machine that was 3 years old. Whats even more sick is that I paid $50 for shipping. I emailed newegg to see what my options are. I'm really starting to think that someone is putting a voodoo spell on me.
Results 61 to 90 of 91
So far my toshiba is working pretty good. I am not having the tuner and video drop out problems that I had with my pioneer. So far the toshiba likes my sony rw's and makes chapters marks. Hopefully, this will last
Of course I spoke too soon. I just attempted to watch my first recorded show on my sony rws and the recording skipped all over the place. I could not even finalize the disc due to the recorder not being able to create a chapter mark or something. I really do not have the patience to try different media, so back to sears the recorders goes. Looks like back to the drawning board again
I bought my DR 4 from SEARS too. In fact I bought 2. Both went back. You might want to try the DR 5. Not as good as the DR 4 but at least the auto chapters worked. Not sure bout media RW media though. I only used Maxell -R. I could not finalize a Sony RW so I just stuck with -R. Right now I have a Sony GX330. Havent played with it enough to give my $.02. Good luck and happy hunting.
I've used Verbatim RWs in the D-R4 every day for 6 months. I always do a full erase after using them, I've had no problems with the discs or recorder.
I figured the recorder probably just doesn't like the sony rws, but I also wanted a better flex mode and maybe DL capability. I might try the DR-5 or wait for the new jvc to come out.
I had the same happen to me a few weeks ago. I turn it on then after a minute I get "ER7071". It doesn't even sound like its trying to load and seems like no power is going to the drive.Originally Posted by johnmoon
I'm considering doing a "buy, switch, and return" to Sears or somewhere else I can find a d-r4. My 90-day warranty expired months ago and I dont have the patience to deal with Toshiba customer service or mailing the crap to them.
Is there a restocking fee at Sears? -
I doubt very much that any retail stores still have the Toshiba D-R4 in stock ... the replacement model (the D-R5) has been out for months now.
I recently downloaded the manual to the D-R5 and it seems that they have dropped the recording modes down to "standard" times like 1 hour, 2 hour, 3 hour, 4 hour etc.
I didn't see anything in the manual about other recording times ala the D-R4 being able to set the bitrate in .2 increments.
Kinda sad.
The D-R4 records 1, 2, 3, 4, 6 hours, it doesn't bitset. It will flex record, but only between 1 and 2 hours, it doesn't work over 2 hours.
I thought you could set the bitrate to pretty much anything you wanted in .2 increments?Originally Posted by samijubal
Or was that only the RD-XS34 model? [the one with the HDD built-in)???
I have just come from my local Superstore (Canada) and the DR-4 is available for $180CAD + tax, so they are still around if you want them.
Toshiba D-R4 Multi-Drive DVD Recorder $96.99 Free Shipping
http://www.buy.com/retail/product.asp?sku=70015759&adid=17662 -
Not completely BRAND NEW as it says it is reconditioned.Originally Posted by MJA
Just to offset the DR4 negativity a bit, I've had mine for almost a year and it has been relatively flawless. I've mostly used Panasonic RAM and Sony RW discs. Surprisingly, the RAM discs seem to crap out fairly quickly - work well for the first few weeks/months and then unit starts popping up various error messages. The RW discs have all worked perfectly so far with no errors (been using a single RW disc for over 3 months of daily recording / erasing!).
PQ is excellent even at low bitrates.
Overall, very pleased with this machine. -
The picture quality is truly amazing. I've seen many retail DVDs that don't look near as good as the discs I've recorded on the Toshiba.
Well folks I may have good news. After sending my DR-4 off to Toshiba three times and still having problems, they are telling me they will swap my DR-4 for a brand spanking new DR-5
I am currently waiting on another FedEx label. I will let you know how things turn out with the DR-5
Well so far so good with New DR-5
Everything works so far.
I would say the DR-4 had a better GUI Interface and was more forgiving with a poor source.
The DR-5 works well for what most folks would want to do.
DVD-RW and RAM work fine. Auto chapter creation works good!
The GUI is very different to the DR-4, but ok. -
Does the D-R5 record in VR mode on DVD-RW discs? Looking at the website, it looks like it does. That's the one thing I wish the D-R4 did.
I bought a D-R4 as well from Sears last week at their model close-out price so it is a bargain. Problem is I am running into the same problems mentioned in this thread.
The -RW discs (TDK) formatting stops at 39%. -R discs (Memorex and Verbatim) that will not finalize. It is very frustrating because I now have 5 coasters. However, when the unit works, I do like it a lot. I can only hope the Toshiba service people can fix it. I need a recorder that is more forgiving with a poor source (as commented by johnmoon) since I am transferring 20-year old VHS tapes to DVD. -
Okay, my first post, and I am having the same problems as most here. First off, my chapters are not working whatsoever, have checked and double checked the settings... still no go. Also, will not format or initialize Fuji Brand DVD-RW, stops at 38 or 39% like others. Lastly, was unable to finalize DVD-R disk when trying to enter a title name. Got Error 14, but after removing the title I tried to put in, it finalized...
I am contacting Toshiba, hopefully they will have a fix. Only paid $99 at Zellers on Clearance, so would like to get it working! -
This is an old post, but I found it when I was trying to find a solution, and I sort of found one.
Just wanted to let you know:
"ER7071" error code probably means there is something jamming the disc drawer or a mechanism in the drawer isn't working right.
I basically fixed it. Toshiba tech support had no idea what the error code was! Called them up and they told me it would be 130.00 to fix and I basically laughed at him and tried to get him to find out what the error code was because SOMEONE must know what it meant! No luck.
So I decided to open up the unit. I saw on the side of the drawer a mechanism with a loop attached that was sitting on the side of what goes through it. So I fussed with it and put it back together. Out of ignorance, I broke a little plastic guide finger that probably helps line up the back of the tray, tried to fix it by replacing plastic finger with a screw, but it was scraping a little. I took the piece out and the recorder seems to work fine without it. If you do work on it, just make sure you line up the lid (has a white track attached) with the white knob finger on the tray when you place it back on. -
I purchased a D-R4 2 weeks ago on final sale at Best Buy. My first impressions about the unit is that it does NOTHING it is supposed to right, and I'm talking about the basivs here. Every timed event I recorded ended in ERR014 using TDK-RW media. Yet the same media would format and record OK when used manually. The same thing happened when recording onto a Memorex -R media. I bought Panasonic DVD RAM media as specified in the Manual but the unit will not even recognize it!!!
I wrote to Toshiba and inquired about a Firmware upgrade. I was asked to phone their Customer Service. I did that. They said someone will be in touch...Some days later, seeing that nobody got in touch, I phoned again. I was told that my first service call was recorded, the request was sent to Toshiba Head Office BUT they have no idea of the outcome. Meaning they cannot tell if a firmware was sent, is to be sent or if anything else is being done about my request. So far I am less than impressed with Toshoba C/S! I got a 10-day extention from Best Buy for a full money back. Hopefuly a firmware upgrade will do the job (if I get it soon), otherwise the unit will be returned and I will be done with Toshiba and their products for good. -
I'm not sure what you mean by recognize it (panasonic dvd ram), but this is my third ram recorder and when I tried discs that I recorded with the other units, I found the only way I could bring up any kind of menu so I could get to different chapters was by pressing the yellow "Easy Navi" (Navigator) button on the remote instead of title or menu button which I thought was weird. Can you get into any function menus to format the ram disc?
As far as your problems with timer recording, I don't know any possible solution, but I know my second machine, a Samsung R-120, will instantly give me an error message as soon as it loses a video or audio signal while recording. You can't get rid of the error message and it just continues recording! The only thing you can do is unplug the thing or shut the power off by holding in the power button. When it comes back your recording is gone because it doesn't burn the final instructions like it normally does when you stop recording. -
Mpheadley,
What I mean by "it does not recognize it" is as follows: when I insert the Panasonic DVD-RAM the unit reports NO DISC. So there is no possible additional actions you can perform such as Format etc...What media have you used successfully so far?
For recording, it works only if I start recording and stop the recording manually. Any timed recordings so far have ended in ERR014, using -R Memorex and -RW TDK media.
I still did not get the Firmware upgrade and it has been more than 2 weeks. Another 2 days to go before the money back runs out at Best Buy... -
The recorder is defective. The firmware update is to fix finalization problems, it won't fix a defective recorder.
How long is your video collection? Days, weeks, months years, decades?
By yoda313 in forum Off topicReplies: 12Last Post: 1st Jan 2012, 08:10 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 07:05 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
My PC will not recognise my MP3- It was fine for 8 months??!
By jenniewb in forum ComputerReplies: 8Last Post: 28th Dec 2008, 12:30 -
How do you keep your computer cool in the hot months?
By yoda313 in forum PollsReplies: 44Last Post: 20th Jul 2008, 08:21
