I have had some success using tmpgenc to convert avi's to vcd but would like to improve the quality. Can I up the bitrate to enlarge the file size enough to fill the whole cd with a 10 minute clip? Is this the best way given that it will only be played on a pc?
Thanks!
I guess a follow up to this question is how can I figure out what bitrate would fill up the cd?
Thanks for any comments -
what you should use is the bitrate calculato that can be found in the tools section of this website...here is a link the a basic one..
http://www.vcdhelp.com/calc.htm
all you do is fill in your info and it calculate it.
by the way...if you are only planing on playing it on a computer...wouldnt Divx be better to use than VCD. you would get much higher quality.
now, if you do make a vcd you will still be able to get a high bitrate...but...since it is only 10min you will be able to get a really high biterate...but with this high of bite rate..you will probably not be able to play it on any standalone DVD player...which basicaly defeates the purpose of making a VCD in the first place
PS: please research more before posting...if you had checked out the tools sections first...you would have found exactly what you needed real quick....but oh well
Thanks for your response air360. I had tried to use the bitrate calculater but couldn't change the "type" from svcd to vcd. Also can I distribute divx on an autorun cd? I have been creating vcd's on an autorun cd with wmp.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
