I have a couple of NTSC MiniDV tapes I want to transfer to Pal MiniDV tapes.
I use Premiere.Can I just capture NTSC tapes to harddrive then just in Premiere load to PAL timeline and export it back to PAL Mini DV tape??
I just want to do bck up,that's all.
No.
Best to get them transferred at transfer house.
If you have lots of time and little money, others will offer shortcuts. -
Then bak it as data to a DVDR.Originally Posted by ribac
If you need a backup, do it as data. Converting in any way to PAL framesize and frame rates will degrade the quality.Originally Posted by ribac
edTV:
Could you explain to me more futher??
I didn't actually Interpret the footage to PAL 25fps.
I just load it to Premiere in the PAL timeline and played back(recorded)to PAL tape.
What would happen If I just capture NTSC tape to HDD then load it as regular
NTSC project and use "Export to tape" to PAL tape??
Is that possile.I just need to back up,because those NTSC tapes I have to return.
So basically I;ll have NTSC RAW footage on PAL MiniDV tape
thanks guys for help -
I'm confused,
You said you wanted to backup the data.
Then use standard data backup techniques. Save what you have to DVD-R.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
miniDV playback
By rgoldwrx in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 22nd Nov 2013, 11:03 -
Whats the actual size of my video?: miniDV NTSC widescreen
By vid83 in forum Newbie / General discussionsReplies: 33Last Post: 26th Dec 2008, 21:03 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
Problem with importing from MiniDV to HDD. NTSC maybe ?
By antoinel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Sep 2008, 17:44 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46
