  1. I´m trying to insert subs into a movie i have, and following this guide :
    https://forum.videohelp.com/viewtopic.php?t=275603 ...
    It always worked just fine... But this is the second DVD i can´t make it work !! PCGDemux shows no audio streams when i click "check a/v delay" in the title i´ve selected under "by pgc". It extracts the audio, but don´t say the A/V Delay, and when i mux everything back togheter with muxman the audio gets out of sync !!
    What should i do? Is there any other (better) demuxing tool that i can use with this guide, or any other way of discovering the A/V Delay?? This is the second DVD i want to insert subs that i get this problem... REALLY ANNOYING !
    |SYSTEM SPECS|
    • Abit NF7-S Rev 2.0
    • AMD Athlon XP 2500+@3200+
    • Corsair Value 1GB DDR400
    • 120gb SATA + 200gb IDE / 7200RPM
    • eVGA Geforce 6800 @ 420/885
    • LG GSA 4082b DVD Burner
    • Prolink PlayTV Pro Ultra
    you can try demux with dgindex or rejig.
  3. I´m trying but no luck... i can´t believe no one had this problem yet !?!!
    PLEASE help...
    |SYSTEM SPECS|
  4. REJIG won´t demux the video !! OMG........... any help?
    |SYSTEM SPECS|
  5. Open the vobs in DGIndex. Then go File->Save Project And Demux Video. You'll get an M2V and the AC3 (if that's what it is) with the delay in the name, plus the D2V project file
  6. Originally Posted by manono
    Yeah, i did that !! But when i remux the video in MUXMAN it gets out of sync either... The delay says its "-219ms"... I´ve tryed 219 and -219 ms ... Both out of sync...
    |SYSTEM SPECS|
  7. Guess you'll have to figure the correct delay yourself then.
