Hi all,
Is Premiere Pro good only for DV ?
Its project settings doesn't have a setting for regular AVI, just DV....
In case I want to work with HuffYUV AVI, will it be OK ? How should I adjust the project settings ?
Thanks,
Zetti
Results 1 to 9 of 9
Not sure about PRO, but I've captured and edited HUFFYUV avi files and edited them with ADOBE Premiere 6.5 without any problems.
Rob -
Premiere Pro is native uncompressed RGB or YUV in varoius bit depth. It can easily handle uncompressed 8 bit 4:2:2 YUV in software or hardware.
Huffyuv is a way to compress a 4:2:2 YUV stream to a file. -
DV format support is an overlay over YUV uncompressed native. It means that DV is only uncompressed when filters or transitions call for it.
http://www.kiva.org/about -
Thanks edDV and Rob,Originally Posted by edDV
edDV, DV is 4:1:1 compression, right ?
As AVI HuffYUV is 4:2:2, and Premiere Pro "Project settings" is stucked in "DV format", wouldn't it imply in additional quality loss ?
I mean, the actual video format would be 4:2:2, while the software would treat it all as 4:1:1....
Thanks again, much apreciated,
Zetti -
If your intention is to work with Huffy codec, then create a custom project setting (not DV of course). This custom project setting is the same as your original footage..Therefore, no re-rendering..Just go through the fields and choose the correct fps,codec,field,audio setting, container, etc....As AVI HuffYUV is 4:2:2, and Premiere Pro "Project settings" is stucked in "DV format", wouldn't it imply in additional quality loss ?
Good luck!!! -
What is your source? Is this just off air TV?
In your other post you said you were capturing TV to DV format.Recommends: Kiva.org - Loans that change lives.
Yes, it's from TV broadcasts only, when I use VHS I go through the DV way always;
THANKS A LOT !
Zetti
Premiere Pro 1.5 cannot import DivX AVI
By Arjun_M in forum EditingReplies: 6Last Post: 10th Jun 2009, 10:00 -
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 14:30 -
Should I export from Premiere using DV or HuffyUV?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Sep 2007, 02:28 -
Premiere Pro 1.5 Won't Import Any AVI? Zoiks!
By glowing_zebra in forum DVD RippingReplies: 1Last Post: 7th Jul 2007, 05:28 -
Premiere Pro to xvid or divx AVI
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2007, 20:48
