Hi all.
I had a LITE-ON DVD recorder, just changed it to a SONY DVD recorder
my problem is that the RW+ disk i used on the LITE-ON will not work on the SONY 1, well they play but i cant erase them or record on them.
is there a way to re-format or get the disks back so i can use them as they are intented.
Try erasing the disc on a PC drive. You will have to re-format on the Sony recorder however, since PC drives can't format for a recorder.
Hi
i used nero 6 to erase all data on the disk, when i put it in the sony the message is simply (can not play this disk).
if i go to MY COMPUTER>right click on DVD drive there is no option to format. any other way i can restore the disk? -
ahhh
i have done it, Thank you. so damn simple when you think about it.
i was proberly over thinking the situation.
anyway thanks again.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
episode dvd disk
By DSLGuy in forum Video ConversionReplies: 2Last Post: 14th Oct 2007, 20:09
