Hi,
Im willing to hide a logo on a TV capture. The logo is in the upper black boarder, so it's quiete easy to hide it.
I don't want to re-encode the video, so the DeLogo solution isn't the one Im looking for...
Ive read here and there that a trick would be to use a black .bmp as subtitle to hide the logo.
I tried to do that, using a red boarder (like with DeLogo) and DVDlab PRO. Ive set just one subtitle during the whole video, but the subtitle disappears whenever I change the chapter or even fast/back forward (Tho, it stays if I let the video running from the beggining).
Then, I tried to set a subtitle for each chapter using frame index to be as accurate as possible. The result is a little better, since there is no logo except when fast/back forwarding and like during 1 sec between 2 chapters.
Does anyone succeeded in the subtitle trick, and if so could help me with the tools/parameters used?
Thx
I don't think most players show subtitles during FF or REV. It's nothing wrong with your idea or your authoring - it's up to the player to decide when and if to render the subtitles. I guess it's even be possible to turn the subs off altogether with the remote?
/Mats -
I agree, but when I go back to normal play, the subtitle doesnt come back, that's what i meant sorry.
Plus, when i try to get them back via the remote, it says subtitles on, but my 'patch' doesn't show up :S
If anyone know another technique to hide a logo without quality loss, Id be glad to hear it (unless it's a geek 50 steps technique). -
A subpicture cannot cross chapter "borders". Put one that ends at the chapter point and one that starts at that same point.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Ah, yes, and after a FF, the player waits for "next" subtitle to appear, and since there is no next, it won't show again. Like when you turn the subs on with the remote - it doesn't come up instantly, but when the next subtitle is displayed.
/Mats -
Originally Posted by SLK001
The basic idea would be to delete the chapters and create a subpicture from the start to the end, but Im authoring a concert DVD, so you get my point...
I think Im gonna give up on this
replicate dirt on logo removal
By mathmax in forum EditingReplies: 26Last Post: 11th Oct 2011, 17:35 -
Logo removal by using 2 sources
By pfxz in forum RestorationReplies: 13Last Post: 8th Feb 2011, 22:01 -
LOGO removal from WIdescreen black bar
By CBrianA in forum EditingReplies: 2Last Post: 6th Feb 2010, 09:10 -
Good Results on Video to Photo Logo Removal?
By Disco Makberto in forum EditingReplies: 28Last Post: 14th Dec 2009, 19:40 -
Removal of TV logo from VOB files?
By guy24s in forum EditingReplies: 6Last Post: 16th Nov 2009, 22:25
