Hi,
I need these three questions answered
1. Do I have to convert my AVI to MPG first to create a DVD-Video?
2. I'll be using TMPGEnc for this.. Any other suggestions?
3. What bitrate should I use 1,110 kb/sec??
1. Yes
2. Tmpgenc is a good encoder and there are plenty of guides here on how to use it
3. Whatever bitrate is required. Use a bitrate calculator to determine what to use.
Start by reading some guides - found to your left - on avi to DVD conversion. Many use tmpgenc, and cover bitrate calculation, resizing etc. Expect the file size of your mpegs to be 3 - 4 times the size of your source avi file.Read my blog here.
Guns1inger,
Did you mean 1 third to 1 quarter the size of the AVI?
Regards -
No, he meant 3-4 times the AVI file size.
It's a common rule of thumb to use 3-4 times AVI bitrate (if the source AVI is DivX/XviD) when reencoding to DVD specs mpg, not to make the mpeg look worse than the AVI.
/Mats -
It's the length of the movie (in time) and what quality you want that determines if something will fit a disc. Use the bitrate calculator to find out max allowed bitrate for a specific disc size and video length.
But 2500 kbps is really low (for DVD specs video), allowing for >3.5 hrs of movie on a 4.37 GB disc. At that low bitrate, I suggest using the "medium" DVD resolution of 1/2 D1 (352x480/576 NTSC/PAL) to avoid compression artefacts.
/Mats
DVD to AVI Or MPG
By AeR0 in forum DVD RippingReplies: 10Last Post: 4th Mar 2010, 19:59 -
changing the creation date of your avi file
By billkater in forum EditingReplies: 6Last Post: 1st Apr 2009, 07:46 -
Vista thumbnail creation crash on .mpg files
By OldAmateur in forum Newbie / General discussionsReplies: 12Last Post: 15th Aug 2008, 15:39 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Batch creation of mpg, mpeg, avis
By silentthread in forum EditingReplies: 2Last Post: 4th Jan 2008, 19:24
