I have been attempting to remove a video segment from an AVI file (divx 6).
When I select the segment I wish to remove (intro to show) The preview shows the right amount of footage removed.
When I save file as AVI all but the final few seconds of the video segment I wanted removed is gone. Most is gone but this seems strange.
When I remove a segment from the end of the file it is fine and what I wish removed is removed. It is just at the beginning of the file that the problem occurs.
Does anyone have any advise.
Using Virtual Dub 1.6.11
Results 1 to 9 of 9
VHS is a dying breed
Sad but true. -
...but Full Processing will reencode the whole movie, while Direct stream wont.
/Mats -
Hold down the shift key while moving the seek bar or pressing the arrow keys to stop only on keyframes. You'll see [K] next to the frame number in the status area when on a Keyframe.
In Direct Stream Copy mode any segment you are keeping must start on a keyframe. It can end on any frame. If you mark the start of a segment on a non keyframe VirtualDub will automatically start that segment on the keyframe immediately before the mark.
If you are only cutting out one sement (or just a few) you can use Direct Stream Copy mode to copy the bulk of the movie without reencoding. Then use Full Processing Mode to reencode the small section that requires it. Finally join all segments back together again with the Append AVI Sement option. -
I was doing Direct stream as I dont need to reencode. IT is the keyframe that was causing it not to cut the whole section out.
Thanks for the assistance guys.
(I always find the answers I need here)
Sad but true. -
Is there anyway to cut at a point other than the K frame?
The K frame position seems to be very erratic!VHS is a dying breed
Sad but true. -
That's because the moron who did the encode didn't know what he/she was doing.Originally Posted by aragorn234
(or didn't create the AVI with further editing in mind)
/Mats -
The default for Divx or Xvid is to create a keyframe every 300 frames or at a detected scene change, whichever comes first. Note that fade outs and crossfades are usually not detected as a scene change.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00
