I've recently started using MEncoder to convert my tivo extracted MPEG2 to xvid to play on my portable player.
I'm still having fun playing around with the settings and so far its been working great.
But one nagging thing about it is that it displays an error saying that it can't find a font (subtitle.ttf or something like that). I tried using the -font setting with arial.ttf but it didn't like it - it wants a FreeType font or something. I've also created \font directories everywhere trying make MEncoder find it, but so far no luck.
This doesn't prevent me for encoding so this isn't a big issue, but I'd like the error message to go away if possible.
Can someone tell me how to setup MEncoder so it find the fonts please? Thanks.
Works fine here. Loads default font from mplayer/font if you don't specify anything. Otherwise -font c:\winnt\fonts\whatever.TTF works.
Then you have options like subfont-text-scale for scaling.
What build of mencoder are you using? Not all builds can load true type fonts. My older builds couldn't until I enabled it after a request. -
Nothing to do with latest really. I could compile a version right now and disable XviD encoding, whilst have it enabled with a 1 year old compile. Font support is basically the same thing. Then there are features like threads in XviD that were only added recently.
Error trying to join FLV files with MEncoder
By sldvd in forum Video ConversionReplies: 5Last Post: 13th Apr 2011, 02:15 -
mencoder Bus 16()?? error
By kabuto in forum Video ConversionReplies: 1Last Post: 14th Mar 2011, 03:03 -
Self Contained FCP MOV to Mencoder H.264 Error
By skywriter in forum ffmpegX general discussionReplies: 2Last Post: 10th Feb 2010, 10:49 -
mencoder error AE_FAAC
By zackiv31 in forum LinuxReplies: 1Last Post: 28th Jan 2009, 20:54 -
Mencoder error while using GOTsent
By d2idan in forum Video ConversionReplies: 2Last Post: 6th Jun 2008, 12:04
