Man, did I mess this one up. I needed more space for the tons of video files I've yet to encode, so I was excited to see a 160MB drive on sale at Best Buy for $60. Bought the last one on the shelf...
I've done the following many, many times with no problems, but I'll never do it again - I plugged in the new drive while my PC was on. Sparks and a plume of smoke - the smell of burning plastic
The new drive was still fine. My OTHER 160GB drive (which had all of my video source files on it) was fried. Dead. Kaput. Mahalo.
Live and learn....
Closed Thread
Results 1 to 30 of 40
I used to do this too! And I did it one time too many, like you.Originally Posted by Soopafresh
I, fortunately, did this at the expense of a spare 70meg drive on an old AT class machine.
I never did it again.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate!
Man!!! if you have done it many many times before, then you were lucky many many times before!!!!
There are some things i will work on while powered up, but surely not installing a HDD or anything in a PC!!!
But that sucks if you lost all that stuff on your other drive!!
But you could have lost alot more!!
WTF ?!?! Are you NUTZ??
Damn brother, I don't believe I would have told that one.
Bummer that things went up in smoke for you.
I ain't gonna hold it against you, it ain't like I haven't ever pulled a bonehead move, or twenty
Keep in mind that experience is not always the best teacher because it gives you the test before the lesson.
Live and learn, if, you are luckyIS IT SUPPOSED TO SMOKE LIKE THAT?
Ive unplugged and plug the power cable to a HDD many times while PC is on with no problems (lucky nothing has ben damaged). I have 3 internal HDD and one external. Guess from peoples experiences, I should stop doing it.
However, is it safe for hot plug devices like SATA drives by connecting the SATA power connector while PC is on.
My personal opinion is when in doubt do not violate case rule 101. even with hot swappable drives, if they are inside the case I follow case rules 101. There are too many electronics inside I could accidentally touch on my way to pulling the hot swappable plug.
Just another tip for those not in possession of a grounding strap, always lean your working arm on the steel case structure. This will provide you with a grounding source before you begin touching internal parts.
To recover your files off the fried drive, you may want to locate another one of the same model (ebay comes to mind) maybe with mechanical issues (bad bearings) and try to replace the controller board. You MAY be lucky enough to get the drive to work.
However, your carelessness in dealing w/ computer HW may prevent you from doing this properly.
/dragan
I agree that even hot swappable devices should have the power turned off. A co-worker was swapping out a redundant, swapable power supply on a server. A pin got bent and it took out the server and brought the corporate network down for a little bit on top of that.
Always better safe than sorry if your money or job or reputation or pride is on the line!!
this reminds me of a time long ago when i thought i knew about computers but in fact did not.
I was attempting to install a bigger hard drive in my computer..my friend had already put the win98 setup files on the hard drive so I could just boot from a 98 floppy and run setup from the hd folder. A girl was coming over an I just knew she would be impressed with my mad computer skillz when she saw me in there workin on it (ha!).
Anyways..i was having trouble and called my friend..he told me i had to set the jumpers and he kinda described over the phone where they are...i said OK..hung up the phone...got the hard drive in and then found the "jumper" I thought he was talking about...what i actually had in my hand was the peice that is supposed to plug into the motherboard and powers the HD LED. I stuff that into where the jumpers are supposed to go...the girl shows up just in time to see me flip the switch...smoke starts coming out of the computer..she laughs at me..and i turn off the computer. The HD LED cable had melted..I brought the hard drive back to my friends house again simply telling him i couldn't get it to work...he plugged it into his computer and said...."theres nothing on this hard drive..did you format it?"...i just shrugged my shoulders. i did format that drive..a quick "electric shock" format i suppose
@greymalkin
Interesting. Connecting an LED lead to the jumpers or even IDE pins should have had no effect. Surely nothing that would cause anything to smoke or catch fire. You may have burned out the LED but that's about the only damage which should have happened. The hard drive should have been fine as well.
I can't begin to tell you the amount of times back in the day that I would tell people who said their drive was dead to flip over the IDE cable(before they were notched) and everything began working as normal.
Thanks for the suggestions on replacing the logic board. I might give it a shot- I even have the tiny torx driver to remove the board. The problem is that if the circuitry or design has changed, it won't work. Had a friend buy 2 of the same model number drives to replace the burned out board on his old WD 40GB clunker, and they didn't even physically fit.
Why'd I do it? Laziness and cockiness. Had the side panel off earlier in the day and was running it open. Saw a molex power connector sicking out of the cable bundle and it was too tempting. Didn't want to harsh my mellow by turning on lights in the room, figured the bling lit case fans would provide enough light to see how the power connector was keyed.
ROLLING ON THE FLOOR LAUGHING TO DEATH!
and I thought I had a bad day??
sorry for your loss!
and remember, nothing is idiot proof,, cuz sure as were on this earth, when someone says they made it idiot proof, God makes a better idiot!!!Motherboard problems, not intermittant anymore!!
holy jesus.. i didnt think people actually did this type of stuff.. connecting live power & ide to a hdd..
i mean seriously, that's really stupid..
i've accidentally disconnected the power and/or ide a couple of times while the computer was on, but never connected it..
i dont mean to bag on you or anything, i just find it unbelievable someone would do something like that..
it's like waxing your modem to make it go faster.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
how to install mp3 player in 1 gb flash drive
By sksingh in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2010, 07:14 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 17:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
