Hi everyone!
I´m trying to convert a divx file with an aspect ratio of 2:35 to dvd, so far i used quenc and a trial version of CCE.
when checking the dvd aspect ratio it tells me its 1.77 and the picture looks a bit stretched, i tried "feeding an avisynth script (2:35) but stiil no luck.
is there any way to maintain thre aspect ratio the same n the final output (dvd)?
I love it when a plan comes together!
you must add black borders to get it to the 2.35:1 ratio. doesn't avi2dvd add that???
or just use convertxtodvd. -
Open FitCD. Either open your 640x272 AVI or fill in 640x272 by "Source" on the left side. Just beside it make sure you have it set for 1:1 monitor since your Source is a 1:1 AVI. Just to the right, by "Destination", set it for DVD 720, and below, check PAL, if PAL, and Anamorphic if you're encoding for 16:9 and leave Anamorphic unchecked if you're encoding for 4:3.
With PAL and Anamorphic checked, FitCD gives me:
LanczosResize(720,446,0,0,640,272)
AddBorders(0,65,0,65)
And since no cropping is required, then:
LanczosResize(720,446)
And since the AddBorders numbers should probably be even numbers, then:
AddBorders(0,64,0,66)
Is there anything especially difficult about that? All you have to do now is to make sure that the encoder is set to encode for 16:9 if using that script.
Aspect ratio and conversion issues with an AVI file.
By destino in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2012, 06:30 -
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 19:25 -
Converting .mov to Flash - Can't Maintain Aspect Ratio
By cchrisj in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2010, 09:53 -
How To Maintain Proper Aspect Ratio?
By Bonie81 in forum Authoring (DVD)Replies: 4Last Post: 2nd Sep 2010, 19:23 -
How can I maintain the Aspect Ratio in MeGUI?
By Newtype in forum Video ConversionReplies: 2Last Post: 1st Feb 2010, 09:06
