  1. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    why are all the ones I've seen long and thin?
    I know it makes it easier to get into tight spaces but can't you get a fatter type that isn't as long so it doesn't stick out as far if tight spaces ain't a concern?
  2. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    There are some that have the cable instead. The length is primarily to make it longer than the end you find on most devices like keyboards or a mouse. It's thin because the ports for USB are so close together. There are some that are the thickness of 2 ports in the part that hangs out of the PC, but it doesn't fit well in the front of many PCs.
    Just accept it and deal with it. 250+ million other people have. :P
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    the Soyo Cigar Pro's are pretty big -- compared to most
  4. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    overpriced too.
  5. I have a pqi 512MB stick that is short and stocky.
    The only difference is mine is 512MB.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    http://www.pcstats.com/artvnl.cfm?articleID=1908
    they look good but again why so thin?
    is it impossible to make it twice or even 3 times the thickness and half the length?
  7. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    This would be the first time Americans like things small and inobtrusive. :P You should be happy with it.
