I have done up several short test export timeline AVI files.
Now I want to delete them, but I get an error saying that they are associated with something and I can't delete, no Yes or NO option. Preimere was closed so that was not it.
I have no problems using files say in a conversion with TMPGEnc.
Any info on this would be appreciated.
Patrick.
Hey, it worked! -
Try cutting and pasting the file into the recycle bin. If that doesn't work thqt means another 'thing' is using the file.
Hey SteveDVD.
Thanks, been there - done that! I had all programs closed.
Just does not make any sense.
Patrick
Patrick.
Hey, it worked! -
No problem SteveDVD -- it's the effort I appreciate the most.
Patrick.
Hey, it worked! -
You can also try right clicking and deleting (It is different then the key) and try renaming the file and then trying to delete it again.
Please help with Premiere. Best way to cut concert into song files
By akalsha in forum EditingReplies: 6Last Post: 29th Feb 2012, 19:42 -
Is there a way to batch convert files in PREMIERE PRO
By mudh in forum EditingReplies: 13Last Post: 12th Oct 2011, 11:23 -
Premiere Elements/DVD files
By Reverend in forum EditingReplies: 6Last Post: 8th Jun 2007, 16:38 -
Premiere 6.5 won't import DV files
By Megahurts in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2007, 21:52 -
DVD to AVI files to edit in Premiere 6.5
By nuts4dv in forum DVD RippingReplies: 2Last Post: 7th May 2007, 01:16
