I'm trying to create a VCD with VCDEasy.
I tried 2 different mpegs.
in both the audio seems fine but the picture is in black and white and flipps. I had a similar problem with Click 'n Burn.
My VCDEasy log looks like this after I burn
This is an SVCD. I tried VCD 1.1 and VCD 2.0 I got the same problem with both while the SVCD did not play on my DVD player.
Internally computed XML generated successfully as "C:\mp3\videocd.xml"
GNU VCDImager 0.7.11
initializing libvcd 0.7.11 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `SUPER_VIDEOCD'
changed publisher id to `VCDEASY_V105'
changing 'relaxed aps' to 0
sequence count 1
adding sequence #0, C:\My Documents\Tom Jones And The Cardigans - Burning Down The House.mpg
APS' pts seems out of order (actual pts 59.226711, last seen pts 59.266711) -- ignoring this aps
pts start offset 0.346711 (max pts = 207.666700)
playing time 207.319989
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
this VCD type should not contain MPEG1 streams
pbc: psd size 0 (extended psd 0)
iso9660: highest alloced sector is 225 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, PAL SIF (352x288/25fps), audio[0]: l2/44.1kHz/128kbps/stereo ...
MPEG packet statistics: 14068 video, 1457 audio, 0 zero, 0 ogt, 35 unknown
finished ok, image created with 16010 sectors [03:33.35]
Cdrdao version 1.1.5
0,1,0: HP CD-Writer+ 8200a Rev: 1.0f
Using driver: Generic SCSI-3/MMC - Version 1.2 (options 0x0010)
That data below may not reflect the real status of the inserted medium
if a simulation run was performed before. Reload the medium in this case.
CD-RW: yes
Total Capacity: 74:58:00 (337350 blocks, 658/756 MB)
CD-R medium: CMC Magnetics Corporation
Short Strategy Type, e.g. Phthalocyanine
Recording Speed: 0X - 4X
CD-R empty: yes
Starting write at speed 4...
Executing power calibration...
Power calibration successful.
Writing track 01 (mode MODE2_RAW/MODE2_RAW)...
Writing track 02 (mode MODE2_RAW/MODE2_RAW)...
Wrote 16010 blocks. Buffer fill min 100%/max 100%.
Please wait while finalizing the cd...
Flushing cache...
Writing finished successfully.
Results 1 to 1 of 1
Automatic page flipping in a video
By ishwinderjauhar in forum ProgrammingReplies: 0Last Post: 10th Oct 2011, 09:04 -
Flipping video import
By Jeff Lowden in forum Capturing and VCRReplies: 2Last Post: 6th Feb 2011, 00:46 -
FlipSmart, house flipping software
By Noahtuck in forum Software PlayingReplies: 0Last Post: 27th Mar 2008, 18:56 -
Video is flipping & in black and white.....
By davidbisok in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2007, 00:08 -
Flipping a video with After Effects, how?
By xxxyyy in forum EditingReplies: 2Last Post: 14th May 2007, 11:24
