I'm running an old G3 iMac and trying to convert AVI files to VCD. Everything seem to be running fine up until the end of the process. At the end I get a bunch of errors and am left with a file tha seems to be the right size but blank. I unchecked the Altivec box and everything seems right. Here are the errrors,
____________________
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `/Users/tonylane/Desktop/S05E06.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
**ERROR: could not stat() file `/Users/tonylane/Desktop/S05E06': No such file or directory
++ WARN:
error while parsing command line - try --help
**ERROR: error while parsing command line - try --help
rm: illegal option -- .
usage: rm [-f | -i] [-dPRrvW] file ...
unlink file
(Super) VideoCD xml description created successfully as `Ducking.xml'
++ WARN:
**ERROR: could not stat() file `Ducking': No such file or directory
++ WARN:
(Super) VideoCD xml description created successfully as `and.xml'
++ WARN:
++ WARN:
**ERROR: could not stat() file `and': No such file or directory
(Super) VideoCD xml description created successfully as `Diving.avi.xml'
++ WARN:
++ WARN:
**ERROR: could not stat() file `Diving.avi': No such file or directory
++ WARN:
++ WARN:
unlink file
++ WARN:
++ WARN:
++ WARN:
**ERROR: could not stat() file `Diving.avi.ff-1.mpg': No such file or directory
.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
(Super) VideoCD xml description created successfully as `Diving.avi.ff-1.mpg.xml'
++ WARN:
++ WARN:
Encoding completed on Sat Mar 11 12:13:17 PST 2006
Results 1 to 11 of 11
Case,
I took out the spaces and re-did the file (convert to VCD in FFMPEGX). This time it didn't error out. I ended up with a .BIN file a .CUE file and an .MPG file. The MPG wuldn't play through MPlayer, VLC or QuickTime though. I burned the BIN/CUE combo with Toast 6 and tried to play it on two machines that I have played VCDs on before. One couldn't read it and my Philips just about had a nervous breakdown (grin). I'm confused....
Tony
I have also tried the straight (non-FFMPEGX) conversion with the same result. I'm sure SOMEBODY else has run into this problem. How'd you get around it?
Does the AVI play in QuickTime Player? 'Cause if it doesn't, then Toast's conversion will fail, as well as ffmpegX's (with Decode with Quicktime selected).
Is your AVI XviD video with mp3 audio? Do you have the DivX Decoder component for QuickTime installed?
What information does VLC give about the video? It does indeed sound as if you probably don't have the necessary Quicktime components installed to play the audio (possibly AC3 audio?).
Well, I added the DiviX QuickTime component and now the AVI plays fine in QUickTime. I'm re=ripping in FFmpegX right now so we'll see what happens. Both video and sound are playing fine in QT so, I hope that solves the problem. I really appreciate all the help, gang!
flv to avi with ffmpegx
By giovecam in forum ffmpegX general discussionReplies: 10Last Post: 6th Mar 2010, 14:52 -
ffmpegX problem
By air in forum ffmpegX general discussionReplies: 1Last Post: 7th Nov 2008, 12:17 -
ffmpegx problems with RM to AVI
By mgarman14 in forum ffmpegX general discussionReplies: 13Last Post: 2nd Sep 2008, 12:45 -
ffmpegx problem: no audio from QT mov to avi
By mekon in forum ffmpegX general discussionReplies: 5Last Post: 1st Feb 2008, 16:14 -
ffmpegx problem
By illuzion13 in forum ffmpegX general discussionReplies: 3Last Post: 9th Jun 2007, 14:34
