    Jan 2006
    n.ireland
    I have bought a Panasonic DMR-ES20D DVD RECORDER.
    Which type of disk no i need to record over and over again using the same
    disk.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    A rewritable (RW) one ?
    If in doubt, Google it.
    Oct 2003
    Scotland
    Either DVD-RAM disk or DVD-RW.
  4. Banned
    Feb 2005
    USA
    DVD+RW works great.
  5. Originally Posted by ROF
    DVD+RW works great.
    I may be mistaken but I don't think the DMR-ES20D supports +RW.
  6. Banned
    Feb 2005
    USA
    in that case I'd stick with the -rw variety.
  7. Member zzyzzx's Avatar
    Baltimore, MD USA
    Exactyl how can I identify a RW DVD?
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Apart from the RW on the packaging or printed on the top of the disc, DVDInfo Pro or DVDDecrypter can tell you.
