Hi there,
I am starting off with an AVI/Divx file, and converting to MPEG(s)vcd. I am converting these files using "Main Concept MPEG Converter". Everything works fine up until about 2-3 minutes from the end(approx. 42 minutes total). The video freezes, but the audio continues to play in the background. It has also happened with smaller files(approx. 22 minutes). I am fairly new to this type of thing, and have not been able to find any relevant info that will fix this problem. Can anybody help with this problem? Thanks.
It could be a corrupted AVI file. You can drop it into VirtualDub and then under 'Video', 'Scan video stream for errors'. If you find some, you can usually cut them out and resave the file.
If you can't find any problems, try TMPGEnc encoder. It's freeware for MPEG-1, such as VCD uses. It's also one of the better MPEG-1 encoders out there.
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
audio stops way before end of converted movie and is out of sync
By jboyd in forum ffmpegX general discussionReplies: 11Last Post: 17th Dec 2007, 06:12 -
burning dvd movies and everyone freezes at end
By bandit1222 in forum Authoring (DVD)Replies: 17Last Post: 14th Dec 2007, 00:06 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Invert/move, the End to the Begin in one clipe MPEG, avi
By arturjose in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 17:09
