i have a usb data cord for it and when i plug it in, it charges but XP does not reconize it at all. and i also need a free sync program for the lg ax4270. my provider is Alltel.
see if this works
http://www.bitpim.org/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i have bitpim and my phone isn't supported with bitpim. i even tried other CDA phone but that didn't work. ive been stuck on this problem forever lol
My computer doesn't even reconize my phone. i think i just need different drivers for my cord? im not sure wht brand the cord is but its supported for the LG VX7000 and does charge my phone. -
well you might have to spring 25$ and buy the program then
Usually they give you a software disc. Just call your provider and let them know and they'll either give you a website, email, or send a disc with the software driver on it. Happens all the time.
so you suggested calling alltel and tell them what i have and they will give me an address for the drivers i need for my phone?
yeah, call your service provider. At the very least they can tell you the manufacturer of your phone and direct you to where you can download the drivers, though most providers actually have a link to the drivers you need.
Again, they may direct you to a site to download, send an email with the driver. I've heard in very rare cases that they'll send a disc via mail.
Do you use a cell phone?
By johns0 in forum PollsReplies: 12Last Post: 23rd Jan 2012, 23:39 -
Cell phone with bad ENS
By MJA in forum Off topicReplies: 1Last Post: 7th Feb 2010, 10:10 -
Ring Tones on cell phone
By BLSAMPLES in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2009, 21:49 -
dvd to cell phone
By molinman in forum Video ConversionReplies: 2Last Post: 4th Jan 2009, 12:25 -
Antenna for cell phone signal?
By SIRCOOKS in forum Off topicReplies: 1Last Post: 27th Oct 2007, 23:38
