Any fans of adult DVDs?
Anyone find that any of the companies employ the macrovision thing?
I know with VHS, I don't think any of them bothered. The main thing being that the cost/profits are so low cost wise compared to hollywood, I guess the adult companies don't think it's worth buying and employing the cumbersome technology. But I would be curious if others may know more on this. thanks.
Closed Thread
as for your question -- it is not 'cumbersome' and VERY easy to employ during authoring ...
macrovision on a dvd is only to prevent copies to tape ...
you might be thinking of something else --
and porn is high profit - low cost (usually)
also the porn industry is the first to use multiangle and other dvd navigation aids ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
DVD Recorder - Copy-protect
By Maniac100 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 1st Nov 2014, 11:44 -
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 07:42 -
Can I copy protect my DVDR's
By 557953 in forum DVD RippingReplies: 5Last Post: 15th Jun 2008, 18:41 -
How do I copy protect a dvd?
By goheadtry in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2007, 18:22 -
password protect movies
By hackerzlab in forum Newbie / General discussionsReplies: 9Last Post: 31st Oct 2007, 11:47
