Hallo.
I'm thinking about moving to linux world also with grabbing clips from my miniDV
camcorder. I saw that there is an application that looks quite nice. It's name
is `kino'. I need some more information, esspecially about quality of grabbed pic
tures.
On windows I am using scenalyzer + main concept DV codec. I'm very glad about th
e quality of grabbed clips. Can You tell me whether grabbing quality is the same
in kino.
There is one more thing I like in scenalyzer. It can split my source into clips
based on drastic change of time that is stored on the miniDV tape. Can kino do t
he same?
Thank You in advance for Your help.
Greetings.
Results 1 to 9 of 9
Originally Posted by pawel7
Beyond all this, programs like Scenealyzer add features for "optical" image processing for scene detection purposes only. Scenealyzer probably uses its internal codec to feed this but maybe you instructed it to use Mainconcept instead, or maybe they use Mainconcepts OEM DV codec internally. Regardless the stream to file transfer is untouched.
Maybe you are using Mainconcept's DV codec for Virtualdubmod for DV-> RGB -> DV
Kino is a simple editor (like Vitualdub) that will import and export DV (like WinDV). As far as I know it doesn't have scene detection features like Scenealyzer.
I'm not sure which DV codec Kino uses to and from RGB. I don't think Kino supports native YUV processing. I haven't used it in months. -
There are two types of scene detection.
Camcorders add metadata for every record start and stop point matched to timecode. This is what consumer capture software uses for "poor man's" scene detection. This works well for camcorder material, but does nothing for captured programs.
Scenealyzer uses "optical" image analysis to detect scene changes. I'm not aware of a Linux program that does the same thing. -
Let me do summary of Your post.
1) "optical scene detection" - used by scenalyzer. You do not know any linux soft that can do it.
2) camcorder time metadata detection
Is the summary above correct ?
If Yes, I have 2 more questions
a) Do You know any linux soft that can detect scenes based on 2)
b) do all (or most) miniDV camcorders add such metadata to miniDV tape while recording ?
Greetings -
b) As far as I know yes. At least Sony and Panasonic. -
Hello
Let me explain:
I have miniDV tape with movie from my vacation. There are a lots of scenes on that tape.
Definition of `scene': piece of movie that has continous time.
I'm looking for a linux tool that will grab that movie from my camcorder and will split it into files where each file will contain one scene.
My question is whether You know such tool ?
Greetings -
No, I don't but you can easily do this under Windows with WinDv or your Scenalyzer and then shift to Linux to edit your files.
I haven't found an editor that I like in Linux so I do 99.9% of video in Windows.
Here are some sites that review Linux video applications
http://linuxgazette.net/issue62/silva.html
http://www.exploits.org/v4l/
http://usalug.org/phpBB2/viewforum.php?f=63
http://www.b-lux.net/courses-multimedia.html -
edDV,
thank You for Your help
I will try to find something I like.
Greetings
VLC (or better?) for grabbing still shots
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jun 2010, 20:58 -
Aspect ratio problem (Linux/kino/QDVDAuthor)
By flonks in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2009, 08:51 -
kino playback speed?
By jdetwile in forum LinuxReplies: 1Last Post: 9th Nov 2008, 20:25 -
FireWire to Kino/dvgrab from Canon ZR70MC ??
By jdetwile in forum LinuxReplies: 6Last Post: 27th Aug 2008, 12:14 -
YouTube grabber not grabbing
By Tbag in forum ComputerReplies: 6Last Post: 4th Dec 2007, 07:22
