going to pick up my first DL discs this week and i was wondering if burning DL is the same as DVD5's or do you have to do it differently?
i normally choose DVD Video in Nero then just drag and drop the Vob's.
thanks![]()
I would just burn with nero and hope for the best...
or search for nero dvd9
or https://forum.videohelp.com/viewtopic.php?t=286029&highlight= -
Yep, what he said.
I'd rip with DVD Decrypter to an ISO image then burn right back with DVD Decrypter or ImgBurn.
I've used both to burn DL and have had 0 problems. -
i was thinking more along the lines of authoring to a video ts folder. is there a software that is easy/capable of doing this and putting the layer break in correctly so i don't end up with a coaster?
I have authored acouple of DL's, i just made an ISO of the VIDEO_TS folder, and burned with DVD Decrypter and let DVD Decrypter set the layer break.Originally Posted by tenders
You can use ImgTools or whatever to make an ISO of your folders.
dvd9 burning!! how?
By angles in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2010, 13:22 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
Burning 10 full length vids into a DVD9
By maggot6sic6 in forum Newbie / General discussionsReplies: 18Last Post: 24th May 2008, 00:06 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41 -
burning error using imgburn DVD9
By mvp in forum Newbie / General discussionsReplies: 6Last Post: 4th Nov 2007, 01:04
