Results 1 to 10 of 10
    Mar 2006
    Please answer this simple question...
    Can blank DVD+RW disks that are purchased in the UK play on NSTC players?
    Help on this subject would be most appreciated.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    not if they are blank
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    and don't double post please ....
  4. Member otpw1's Avatar
    Jan 2005
    midwest USA
    A blank dvd+rw won't play on anything.
    It's blank.
    Will a dvd+rw work in your recorder?
    Check to the left for your model.
    edit
    bjm is too fast for me.
    A good divorce beats a bad marriage.
    Now I have two anniversaries I celebrate!
    Mar 2006
    Sorry Mod, I will delete my other post.
    It will have data stored on it of course, what I mean is it was originally blank and not an official DVD.
  6. If you create an NTSC movie DVD it will play on NTSC players. Most NTSC DVD players will not play PAL content.
    Mar 2006
    Does PAL apply to things off the internet?
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Can videos on the internet be in PAL format? Yes.
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You need a device compatible with the format, both player and TV. Some are compatible with both. This does not apply to a computer, it will play either.
