if i have a movie file on my pc and want to record directly to my stand alone dvd recorder on my tv, is there a way i can do this ? if so how and what would ineed (programs ect.) i don't want to burn it on to a disc using my pc, i want to use my stand alone dvd recorder.
Results 1 to 10 of 10
do you have a "tv out"(svideo or composite) on your computer graphics card?
You can get a cheap used video card with a tv output on auction sites for a great price if you don't need it for high powered gaming.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
once i get that , do i need anything else(CABLE ,PROGRAMS ECT.) or is that the only thing i need.
Well depends on the card and your tv/vcr/dvd recorder.
Most video cards with tv out tend to only have svideo out. Which means your vcr/tv will need a svideo input. Or you will need a realatively cheap svideo-to-rca cable adapter so you can plug into to your regular inputs.
Of course if you want sound you'll need a ysplitter to output your headphone sized output jack to your input on your tv (if its a mono tv/vcr just use the left plug or get a joiner that can make stereo into mono).
Then you'll be set. These cables and adapters generally don't cost much more than $5 or $10 USD apiece and if you've been doing a lot of home stereo stuff over the years chances are you have these laying around somewhere.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
what type of card would be good for my pc based on this info....
dell Dimension XPS Gen 2
Processor Intel(R) Pentium(R) 4 CPU 3.00GHz
Processor Speed 2.92 GHz
Memory (RAM) 512 MB
Operating System Microsoft Windows XP Home Edition -
Depends on how much you want to spend. Set a budget and go from there. If you're not going to do a ton of pc gaming get the cheapest you can find with an svideo card. Ati or nvidia - doesn't really matter if your not going to do high gaming with it.
Though you'd propbably want one with at least 64mb ram on it if you were going to do SOME gaming. I'm sure 128mb cards are pretty cheap for the older generation models.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
maybe some gaming but mostly for video transferring stuff....do i need other cables besides the svideo....
How to record HD TV?
By iRecycle in forum Capturing and VCRReplies: 19Last Post: 28th Nov 2014, 19:46 -
Possible to record HD TV Via Cable
By onesikgypo in forum DVB / IPTVReplies: 10Last Post: 21st Jul 2012, 13:08 -
How can i record from the tv to a tv recorder?
By sluv2 in forum DVB / IPTVReplies: 6Last Post: 2nd Feb 2011, 19:10 -
Cannot record in +VR mode
By hornsfan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2009, 22:40 -
How can I record without TV card?
By Xavier in forum DVB / IPTVReplies: 4Last Post: 17th Apr 2008, 07:58
