  1. Hey
    I have a problem I hope somebody can help me with. When I try to convert a divx to an mpg with TMPGEnc the sound vanishes. I´m using the right template to fit the fps. What can I be doing wrong? I have installed Kristal codecpack and I´m using lame as an external mp3-encoder.
    Please help
    Happy New Year
  2. Why do you need MPERG3 codec for making VCD?
    Otherwise. Try to save audio stream from DIVX to wav and ask TMPGEnc to work with wav instead to work with audio stream from DIVX video.
  3. I saved audio to wave with nandub and it seems to WORK. Tjohooo
    Thanx alot Condor !!
  4. I got the same problem! how do I have the audio from a
    divx file? and wont there be a sync problem?
  5. NANDUB? where can I get this? I dl'd shrek and want to make vcd's of it.
    Freddie,
    Netherlands
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  6. Proton\Hoffman,
    Not only does Nandub work but you could also use VirtualDub to load the Divx and save the audio as a wave file. You should be able to find either on the left side of this site in the Tools section. Laters.
    Regards,
    The Daywalker
