    Jul 2005
    Norway
    I'm planning on ripping my entire DVD collection to put it on my HTPC, and I was hoping you guys could help me get started.
    What I want to do is:
    - rip my dvd
    - encode it to a good video format (divx/xvid) with surround audio if available
    So far I have managed to rip a dvd with DVD Decrypter, but I do not know what my next step should be.
    What software should I use? I have Gordian Knot installed, and I've seen an app called Robot4rip mentioned. Am I on the right track, or are there other, simpler, better appz out there?
    A few concrete questions:
    1. which videoformat would you recommend?
    2. do I store the audio in AC3 like it is on the dvd, or do I compress this?
    3. how do I get the movie subtitled? do I "imprint" the subs in the video file, or should I make a subtitle file that my player can read?
    Do you know of any good guides that can get me started?
    Appreciate all help and comments!
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I like AutoGK, xvid and AC3. It also caters for subtitles.
    If in doubt, Google it.
