Yes I got a source video in MPG2 format with a durration of 24 minutes per episode. I just got divx 6.1 and I know i got to use the multipass encodes in divx. Anyway what is best settings to get a high crisp video from divx with a file size to be roughtly around 200MB's give or take. Could you explain on what settings to use to get what I am looking for
1st pass
main tab
Certfication profile: unconstrained
bitrate: multipass 1st pass 1400 kbit/s
if i have bitrate based: quality based 5
codec tab:
Encode method: extreme quality
frame control:
bidirectonal coding: adaptive multive consecutve
max key frame: 300 frames
keyframe threshold: 50%
Motion estimation:
Quater pixel unchecked global motion comp unchecked
Video tab:
Video resolution:
keep resolution
Image processing:
Noise reduction: off
Psychovisual enhancements off
interface progressive source
quantization H263 optimized
Nth Pass
main tab
codec tab:
frame control:
Motion estimation:
Video tab:
Video resolution:
keep resolution
Image processing:
quantization H263 optimized -
Time = 24 Minutes or 1,440 seconds
File Size = 200Mb or 1,600mb or 1,638,400 kb
Bitrate = 1638400/1440 = 1137.8 kb/s
I would use 1st pass with a bitrate of 1137, leave the rest the same.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
