  1. Hi all
    This is my first time posting on this forum
    and i would like instructions on how to save my 30 how to video's
    on dvd instead of saving them on my desktop
    Kittians
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    OOOOOOO-K
    In order for us to tell you how to do what you wish to do, you need to give us a bit more info.
    Do you want these playable on a settop DVD player ?
    If so, a regular DVD player or a Divx/xvid/raw MPEG capable player ?
    If so, encode if required to divx/xvid/MPEG and burn to DVD as data.
    If not, the process of getting files from your computer to "spec" DVD disc goes something like this:
    1. Acquire source (capture/rip/DL .... whatever)
    1.b) Make any modifications / edits / filtering (if necessary)
    2. Make sure your source is DVD-compliant - if you changed the video via 1.b) then you'll have to re-encode. You may have to re-encode even if you don't make any changes.
    3. Author.
    4. Burn.
    5. Test playback on a settop player.
    What's your source ? Downloaded divxs ? captured DV edited in a NLE ?
    Please supply more info as above.
    If in doubt, Google it.
  3. Originally Posted by jimmalenko
    OOOOOOO-K
    3. Author.
    4. Burn.
    hI Jimmalenko
    I have brought 30 basics video's on internet marketing which is save on my desktop on my computer
    I would like to be able to save them on dvd
    but i do not have the knowledge to save them on dvd
    That why i need instruction on how to save them on dvd's
    example saving the text on floppy but instead i would save them on dvd's so i can watch them on my portable dvd player
    Kittians
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What type of files are they ? (WMV / AVI / MPEG / Other ?)
    Once you find out what type they are (hint: GSpot should be good for this), click on the All Guides link in the menu to the left, and choose "<my file type> to DVD> in the conversion type dropdown box.
