I'm looking for a program to split a large video file into a lot of small clips.
Like: mark in, mark out, mark in, mark out..... without having to save after each cut.
Something that has a timeline with thumbnail view if pos.,
that will save without re-encoding.
I have tried Easy Video Splitter v2 but the cursor moves way past the mark in
or out point with just a touch of the mouse.
Hi sorefinger,
I think AVCutty might do what you want - it's been ages since I've looked at it, and even then it was just out of curiousity, so I never really delved too deeply.
Can you use the cursor controls with Easy Video Splitter? If so, place the cursor close to where you want it and refine its position by single keyboard strokes - you'll get it exactly where you want, and it won't move...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Oh well - 'twas worth a try...
Not so "easy" then? Not too well named...
Carpe diem.
Ulead Video Studio 9 will do it all, multi trim video and save without re-ecoding
Result!!! And thanks for posting your find - others will benefit.
Carpe diem.
Here is a how to
Ok just insert your avi or mpeg file then goto multi-trim video mark in out, in out....
then ok to go back to time line or story board. You wiil see all your clips at the bottom, change the view so you can see them all, then click on the first clip, go up to "File-Edit-Clip-Tools", then select Clip go down to "Save Trimmed Video" then click on the next and do the same and it will save them in your "Working Folder"
Searching for a Program for Syncing Music to Video clips.
By benjzx in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2010, 20:12 -
Splitting programs in program stream
By s0tt0 in forum DVB / IPTVReplies: 2Last Post: 13th Apr 2010, 06:12 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:23 -
Video splitting program
By Gruelius in forum EditingReplies: 0Last Post: 24th Feb 2009, 11:05 -
Which program can see individual video clips on a VIDEO_TS folder.
By ljs3 in forum MacReplies: 3Last Post: 28th May 2007, 09:04
