I recently returned from Russia (BRRRRRR...yes it was COLD) anyway, I had a friend help me document a conference with his Sony Mini DVD Camcorder, I used my usual Canon and Sony DV Tape Camcorders.
Question! --- how can I convert his VOBs to AVIs for editing in Vegas 6b. I tried to convert them to mpegs using VOB to Mpeg software but the file is soooo jerky on the time line of Vegas that I can't use it. It's just to unstable. Are there any suggestions from the Pros out here??
Thanks in advance for your help
Results 1 to 9 of 9
"You have not because you ask not"
James 4:3 -
Is it PAL?
http://www.kiva.org/about -
I don't believe it is .. how can I tell?
James 4:3 -
It was bought here in the States.
James 4:3 -
Then I can't explain the jerky playback. Try importing the VOB directly into Vegas. Rename it as "MPG" if necessary. Keep Vegas at project DV format.
Once the video runs smoothly, others can advise you of audio extraction.
I'm not importing DVD currently. -
I actually did rename the file to .mpeg and that is when I notice the jerky motion.
James 4:3 -
PS: Best to try short clips first until you get the process worked out. MPeg2 to DV will take awhile to convert.
Did you "selectively prerender" or "render to new track"?Originally Posted by GT Music
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 11:02 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 14:33 -
Mini DV recorded on Sony does not playback on JVC (but opposite does)
By joweyenb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 6th Feb 2009, 07:39 -
Editing DVD recorded using Sony DVDirect
By Bryce2k5 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jan 2008, 10:02 -
Computer reports mini dvd 8cm as blank. Sony HDR-ux7. Recorded in AVCHD.
By conan48 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Sep 2007, 19:19
