Hi All,
I've a Canon XM2 and have yet to clean the heads. I've had one short instance where the message "Clean Heads" flashed up, and there was a few seconds of horizontal bars of previous footage.
I'm using the same 5 DV tapes that I always have. No swapping between brands.
Can anyone make recommendations on what to use / not to use to clean the heads? I ask because I've read that some head cleaners are (too) abrasive. I've also read that I can use isopropyl alcohol on a material that won't leave strands behind (a coffee filter instead of a cotton bud).
I don't want to screw up a decent camera...
So, any decent head cleaning tapes out there? Or do I use a small amount of alcohol on (what?) cleaning material?
Cheers,
Daamon.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I'm no expert but since you asked... I just use the store bought tape cleaner. I think that is what Canon recommends.
I know the recommendation is to use as little as possible but on the flip side what is not enough? One time I went to shoot and luckily tried to playback some footage on a previous recording and the preview had horizontal lines running it through it. If I had recorded without cleaning it would have been worthless, these lines didn't show up while recording in the preview but would have on the recording.
I don't know if that's such a bright idea, I'd imagine they do have a life expectancy.Originally Posted by daamon -
tips on cleaning here:
http://www.taperesources.com/useful_info.html#article4 -
Thanks guys.
Carpe diem.
Difference between Canon Vixia HF-20 vs Canon HF-S20?
By Wink in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Nov 2010, 17:46 -
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jun 2010, 12:47 -
Canon XM2/GL2: Wireless Lavalier Mic Question
By Xenon77 in forum Newbie / General discussionsReplies: 9Last Post: 29th May 2009, 21:25 -
Protecting Canon XM2/GL2 Lens
By foxbox in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2008, 09:48 -
Canon XM2: 'Rippled' telephoto picture?
By yukon33 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2008, 18:24
