I want to somehow save this image as a jpeg, but it's htm. Is there away for me to change it to jpeg somehow?
Here is the image:
http://www.joereloaded.com/Reloaded/joereload1.htm
Results 1 to 15 of 15
What We Do In Life, Echoes In Eternity....
looks like jpg here,
http://www.joereloaded.com/Reloaded/Joereloaded.jpg -
Thanks guys, it always should up as .htm (address undedr properties is http://www.joereloaded.com/Reloaded/joereload1.htm).
Had to view the source code to get the www.joereloaded.com/Reloaded/Joereloaded.jpg link
why is it when you guy see it it's jpg, and I see it, it's htm? Which is why I was unable to save picture asWhat We Do In Life, Echoes In Eternity.... -
Hover you mouse ovee the image and right click...
htm is the webpage itself which contains the code for the page that you see when you view source.
Edit: just noticed they disabled right click on the image.... You can do that using Javascript, amateur trick for preventing you from saving. -
Ditto that was going to be my suggestionOriginally Posted by greymalkin
Simple and easy. Just copy and paste into your favorite photo editor and save as a new picture
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
A simple drag & drop usually works too. Just left click the image and drag it to your desktop, but then I'm also using firefox so right click and save image worked for me too. If you ever did want to save a whole webpage as a jpg, snagit works well.
http://www.techsmith.com/snagit.asp -
big problem with print screen is that it's limited to the resolution of your monitor so if it were a high resolution image you were trying to download it would look like ass if you tried to print it out or manipulate it.
FB-DIMM are the real cause of global warming -
I right clicked no problem and chose both "view image" and "save image as", i am using firefox.
Someone must be using IE
All set thanks guys......
here another tip....now i am using IE6 sp2, i find on some webpages where it won't let me do a right click to save a graphic........ I'll do a save as, from the browser file menu, and pick "webpage complete.... what that does for me it save both the webpage and in a seperate folder all the graphics of the webpage!!Originally Posted by Denvers Dawgs
now the webmaster does have a few tricks to prevent certain things.. smile.. and that where the printscreen come in smile.... -
Thanks again for all this info....
Extracting the video file from an .htm
By Enthus in forum Newbie / General discussionsReplies: 20Last Post: 31st Jan 2016, 01:36 -
exporting a captured image as a JPEG file
By altagracia in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 22:59 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 05:14 -
need to repair mp4(and jpeg) file..
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 13:09 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
