    Oct 2005
    i have the sony m2 and it records in mpeg 4. i was wondering if there was a way to import it onto adobe premiere pro. i have so video of me and my friends snowboarding that i wish to edit. any way i can import it? thanks in advance
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You can always decompress it first, then import as raw YUV and audio.
  3. Member daamon's Avatar
    Melbourne, Oz
    Another way would be to convert it to DV AVI (the format that Premiere likes the most).
    I don't know, but maybe VirtualDubMod can open MP4? If so, download and install the Panasonic DV Codec (if you don't have it already) and save out to DV AVI using that.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Oct 2005
    how do i decompress it cause the second reply didnt work.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    is it a mp4 file? or avi?? or mov?
    if mp4 or mov try MP4Cam2AVI and then try import it in premiere.
    and doesn't the camera come with some tools where you can convert to other video formats?
  6. Member edDV's Avatar
    Mar 2004
    per
    http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_DisplayProduc...me=specs&var2=
    Movie Mode:
    MPEGMOVIE 4TV (MPEG4) with Stereo Audio (640 x 480, 30 fps/2.88 Mbps Bit Rate);
    MPEGMOVIE 4TV (MPEG4) with Stereo Audio (320 x 240, 30 fps/975 kbps Bit Rate);
    MPEGMOVIE 4TV (MPEG4) with Stereo Audio (320 x 240, 15 fps/277 kbps Bit Rate)
    Oct 2005
    it worked... thanks alot
