Hi All
I am trying to capture a still image from my camcorder. I capture the footage via premiere pro 1.5. When i have done this and look at the footage in the timeline I cannot find an option to capture a still image. Fisrt of, can you capture a still image? If so, how is it done?
My main aim is to choose the image send it to photoshop for it to be enhanced for best quality.
God bless premiere pro 2.
Cheers Josel
Since the resolution of the video is probably only 720 x 480, just make the preview window that size and do a screen capture.
@ josel: No need to fart around with PowerDVD or making the preview window huge.
The simple answer is "Yes, it can be done", and here's how:
1) Set the timeline so that the frame you want to capture is showing in the preview window.
2) File -> Export -> Frame. Click "Settings" to choose between Bitmap, GIF, Targa or TIFF. Choose your destination and save.
As you're wanting to toy with it in Photoshop, I'd recommend a bitmap - it'll be a big file, but it'll be the best quality as there's no compression. You can save to other formats from Photoshop.
As you're in the UK, you're in PAL-land. The resolution of the frame will be 720 x 576. If you try to make it any bigger than this in Photoshop you're likely to run into blockiness and "large pixel" issues.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Pleasure.
Carpe diem.
Capturing still images - keep quality
By CharlesH in forum Capturing and VCRReplies: 1Last Post: 6th Apr 2010, 18:39 -
Capturing Images on the PC screen while on U Tube
By bryankendall in forum ComputerReplies: 4Last Post: 24th Dec 2009, 13:29 -
Capturing and Downloading Images
By Teac23 in forum ComputerReplies: 2Last Post: 21st Dec 2009, 12:04 -
By Teac23 in forum ComputerReplies: 6Last Post: 27th Nov 2008, 09:52 -
Crazy, wavy black lines on capturing from jerky video (images&vids in p
By osteopants in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 11:25
