Build 2.1.0
I can set it in the option screen. But when I press the background button it soens't work
Guido
You asked for the feature... You didn't expect it to work did you!!!!
Can you redownload & see if it does now....
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 09:35 -
DVD Decrypter doens't see media
By happydog500 in forum AudioReplies: 22Last Post: 28th Jul 2009, 23:41 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
