Ok, this is weird!
After my friend showed me how totally excellent SVCD2DVD is I decided to get it myself.
However, I seem to be having some issues which I don't understand.
It starts up and after the splash screen I get:
Close that window, carry on building the video stuff, adding assets etc etc.Version: SVCD2DVD 2.0
Build: 2.0.2146.38069
Type: System.ArgumentException
Source: System.Drawing
Message: Invalid parameter used.
InnerException:
StackTrace: at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.xbce0680d1ae3e 0bc(Image x7b28e8a789372508, Int32 xdc1bf80853046136, Int32 xb0f146032f47c24e)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.x20aee28197748 0cf()
at x3284ccece41ee22b.xddb8d1ea6c9958c7..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
Click the button to make the DVD and I get another error, actually a series of them, here's one:
I asked Chris via email about this on Thursday night and he sent me a new build on Friday morning (I have to say I'm damned impressed at your level of support!!) but that did the same thing.Version: SVCD2DVD 2.0
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xf42ff19ecf5d2596.x1ef984aa3cc71 762()
at x3284ccece41ee22b.xf42ff19ecf5d2596.x46438c7b1eac1 4ab()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
I've currently got installed the version that works for my friend - thought that might be the answer, but no
I've got .NET 1.1 and SP1 for it installed. I've tried uninstalling SVCD2DVD and .NET and putting the whole lot back on, to no avail.
I thought I might have had an answer last night, I have a beta of MSN messenger, so I took that out too - thought that had a relationship with .NET. Nope, no difference.
Dunno, run out of ideas here and I'd like to think that I'm not a total computer numpty (having worked in IT for 15+ years...).
Any suggestions short of totally re-installing windows gratefully received...
Andy
Can you try the latest version on the website (v2.1) and if that doesn't work can you post the error again?
Ok, here we go, previous ver uninstalled, new ver now on, same (type of) error.
This is on startup after the splash screen (or maybe even *caused* by the splash screen as the splash screen remains with a seperate icon on the task bar (with a little blue, yello and red squares icon *as well as* the normal footbal icon thing)
After adding some assets to a test job and clicking "make quick DVD", I get:Version: SVCD2DVD 2.1
Build: 2.1.0.0
InnerException:
Over to you Chris!Version: SVCD2DVD 2.1
Build: 2.1.0.0
Source: SVCD2DVD
InnerException:
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
Andy -
Oh here's the taskbar icon thing - thought it might help rather than my crap verbal description
Ok. Can you "reset to Factory defaults" in the settings and then close the program and restart?
Aha!
Got no error this time!
Some rubbish thing in the settings or corruption in the settings?
Thanks Chris, you are a star!
Bd-RB Setup
By Marco33 in forum Authoring (Blu-ray)Replies: 24Last Post: 7th Jan 2012, 18:37 -
Need help to setup
By thecaveman in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 14:35 -
What setup is this?
By therock003 in forum AudioReplies: 12Last Post: 5th Jan 2010, 06:58 -
Help with HD Setup
By 24inchdubz in forum DVB / IPTVReplies: 1Last Post: 8th Jul 2009, 22:13 -
Best Setup For My Needs
By ginakra in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Apr 2008, 09:11
