Why cant sony support Xvid files? I really like Xvid. I can render videos in Xvid using Vegas, but I cant use Architect with the avi's ive rendered. It doesnt make sense.
However, I do have some videos I would like to use to make a dvd with architect. They are in the Xvid format. I tried using Nics FourCC Changer to change it to divx to be read by Vegas, so that I can render it in mpeg. However, it only opens up the video, not the audio. It tries to but goes very slow, or dies. Can anyone point me in the right direction to get the files that I want onto Architect? Thanks in advance.
This would be better in the authoring forum. You may better replies there. Moving you.
Remember - Vegas and Architect are professional tools - video pros are rarely interested in working with xvid/divx source material.
/Mats -
vegas will support divx to a point (depends on version)-- and xvid sometimes if you change the 4CC to divx ..
this is not always the case though
vegas does support all types of H264 though - as well as mpeg2 and vobs"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the replies. I dont know why pros dont like xvid, i kinda like it. But what i ended up doing is using Nics FourCC Changer to change xvid to divx, so that I could at least open the video up in Vegas. Then I used a separate program to rip the audio, combined the audio with the video in Vegas and then rendered it as an mpg. The audio was synced in the beginning, but off in the end of the video so I had to do some tweaking to get it synced. Seems like a lot of work just to get these files compatible with Architecht.
But thanks for the replies, and the pointers. I guess I will try to stay away from Xvid. -
they like xvid - but it is a delivery format, not a editing format per say ...
Having trouble importing avi's (divx/xvid) and mkv's into Vegas 10
By mr-scarface in forum Video ConversionReplies: 11Last Post: 17th Jan 2012, 10:11 -
Save Xvid from Sony Vegas Movie Studio
By Cazz in forum EditingReplies: 12Last Post: 29th Jun 2010, 11:50 -
Importing xvid and divx into vegas - a solution ?
By BJ_M in forum Video ConversionReplies: 55Last Post: 13th Apr 2010, 15:16 -
Vegas 64 can not output to XVID ???
By moprh1 in forum Video ConversionReplies: 4Last Post: 27th Dec 2009, 02:14 -
Vegas, Xvid Encoding, Max Bitrate 56kbit only
By kidcash in forum AudioReplies: 3Last Post: 26th Dec 2007, 00:08
