Hi,
How to extract sub menu from DVD menu ??? (sub menu not the menu)
Best regards
I'm not sure if I understood your question correctly... If you want to 'capture' a special menu from the dvd, you can use any rip/demux program therefore. You will get a mpv (or m2v) file with the video (which may be just one frame) and the 'underlying' subpicture (as well as an audio file, if any).
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 10:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 12:25 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
Is it possible to extract the video from a motion menu?
By mjvgiese in forum DVD RippingReplies: 2Last Post: 3rd Dec 2007, 22:31
