I captured a 1 hr video and it is about 2gb in size.
I would like to either convert it to AVI or find some program to edit it since I only want a portion of the video to save.
I tried AutoGK but when I try to bring the video in I get "No video stream was found". This video plays fine in the original file.
I have also tried opening the file in Adobe Premier to edit or convert but I get "Unable to open that file. File was recorded at an unsupported rate......."
This is a capture from Tivo so it named it "xxxx.tivo". I assume it is in the format of mpg, mpeg... something like that.
Thanks for any help,
Debbie
Do this: Download the latest version of Gspot and drop your video into that. It will tell you if you have the right codecs to display.
If you captured it, what format did you capture it with? Not that familiar with TVIO.
But once you determine the format, then you can pick a conversion method/program. You can check the guides to the left under 'CONVERT' to select what you need to convert it to the desired format.
Do a little investigation and get back to us. -
Thanks for the replies
CaZeek that program you mention did just what I wanted with a bit of playing around and figuring it out first.
Thx for all your help,
Debbie
How to Handle HD Video
By djtech2k7 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2012, 20:50 -
HELP!!! Can't handle home video..........
By George Bazeley in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2011, 10:23 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 10:06 -
How do presets handle video...
By bsuska in forum Video ConversionReplies: 2Last Post: 23rd Dec 2009, 09:11 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 15:50
