    May 2001
    New Zealand
    Hi.
    I have a Pioneer DV-535 DVD player. In the old version I gave up on it because the picture was on the left side of the TV.
    Downloaded the demo of the above version and you indeed done a great job with the layout and the speed of converting regular SVCDs to DVDs however this problem is still there and will most likely be the reason I don't buy it. The DVDs play back file on my PC.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Have you tried the "Apply Pan & Scan Info" in the settings?
    May 2001
    New Zealand
    Thanx for the tip. But no it's still the same.
    Guess I'll have to revist this when I get a new DVD player
