    Feb 2006
    Singapore
    Let's say I encode a video file and while doing that, I surf the net, liten to music, MSN etc etc...would it affect the video outcome as in the video might come out badly or some part became jerky etc etc?
    I tried finding information about it but cant find any.
  2. No it wont,But it will take more time.Takes Longer with more Stress on the CPU.
    USA
    While you are encoding, take a look at your CPU usage in Task Manager. You will probably see it is using close to 100% of your CPU.
    Generally, no, you wouldn't want to run any CPU intensive programs while encoding. They would have to take some of that 100% usage. That would normally just slow down the encode, but it could cause problems. A lot depends on what else you are doing, and how your computer is set up.
    I would just leave the computer alone except for a little net surfing. If it's a long encode, do it overnight. I have messed up encodes by running a few too many other programs while encoding.
    Feb 2006
    Singapore
    Great!
    Thanks for the info & advice.
