i have a dvd here that i got from a concert i played at. is it possible just to take the songs off the dvd and save them as like mp3 files?
Results 1 to 9 of 9
Well I guess if you could rip the DVD in some sort of stream rip mode to extract just the audio then convert that to Mp3 and use an Mp3 cutter to divide it up into files. I don't have the exact names of tools handy though.
DVD Audio Extractor form the tools section here worked for me. Extract to MP3 or Wave files for example, Then I burned as Audio CD.
has a fully functional trial version. -
it worked great! thanks
Does anyone know of a program to decrease the size of the mp3s? to mp3s i made form this disc are like 32mb. i want then to be around 5mb if that's possible. -
Actually if you choose custom settings on step 2 of 4, then disable VBR, then you can choose a constant bitrate of 32 to 320kbps which will affect size. Also Algorithim quality speed vs quality. Hope this helps.
Also you could use wma and it puts out a lot smaller file size. Or Mp3pro.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
yup, when I stumbled on that little gem and found that it just worked. One program to get to mp3 or wave and have the sound track ready to burn into a Audio Cd, great.
I plan to buy it and hook my turntable through the receiver to a DVD recorder as a simple way to get vinyl to CD using that program. I have a huge record library all the way from single sided 78 RPM to Ep, 45's and 10" and 12" LPs to convert.
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
