About at my wits end. After 2 boxes of CD-R's
I have a Pioneer DV-334 that is stated as it works with VCD's.
1.)I have tried Nero 5.5 with all the instructions here. You can here a bit of the Audio but video is totally screwed.
2.)Ulead DVDMovieMaker can't find the CD-Writer. (Panasonic SAF CD-R 2206..Old 2x Writer)
and the *.ixa "ISO" it make fine. Any program you know will burn this?? Otherwise I may have to spend $400 on a CD-W that that state is "compatiable".
I'm trying a few others.
Can anyone that has the Pioneer DVD Player stated above tell me if they every got a VCD to work on it and what the used to do so??
Please be detail, replys like "It works here" don't help me much.
Cheers
Results 1 to 1 of 1
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Pioneer BDR-205 requires HD video card to work??
By lafjax in forum DVD & Blu-ray WritersReplies: 4Last Post: 1st Jan 2010, 11:51 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
