I just finished encoding to VCD, and I got a perfect file.
The only problem, is that audio has 50msec difference with the picture...
How I can fix that, without re-encode the whole movie;
We talking about freeware solutions
Thanks!
I think you can (don't quote me now) convert VCD to MPEG again (minor changes in header info), I don't know what to use for that.
But, once you do that, you can do a simple de-multiplex of the audio/video tracks, then re-multiplex the two again using bbMPEG, which has a setting for ms delay for video and audio. You should be able to set it appropriately.
Please, if someone can explain how to do this better, it would help me out too (I know the theory, never actually done it yet!) -
...or if you're sure about the 50msec, De-multiplex it, edit the Audio file and cut out the 50msec and then Mulitplex it .. and burn!
Thanx/
Lars -
Thanks for the replies...
I'll try BBmpeg
@lnetzel: I already try that, but it doesn't work correct...
I tried several times in the past (not this time) to:
De-mux mpeg > load mp2 to a sound editor > put/get delay > reencode to mp2 > re-mux (with TMPEGenc)as vcd
Result: Hick up audio effect....
Audio delay reported in MKV and what to do with it when adding new audio
By pascal in forum AudioReplies: 14Last Post: 30th Dec 2011, 11:07 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 12:50 -
video/audio delay
By cyber69 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 14:45 -
Audio delay.. can anyone help?
By denadel in forum AudioReplies: 5Last Post: 31st Dec 2007, 11:14 -
MeGUI Audio Delay
By kingofking in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 14:55
