Hi,
I have latest version of FFMPEG thanks to celtic_druid
I tried to convert AVI to RMVB but the image is very bad (vcodec rv20) ...although I used the lowest frame size - sqcif or qcif, I tried also to increase the bitrate...same result
I don't know what codec I must use to encode audio for RMVB either
What can I do ? I want to use a freetool and with command line support
I could have swore that Real used to give out their stuff for free? Not any more, I guess.
You don't have to use RealAudio as RMVB's audio. RMVB accepts MP3 audio too. -
Technically RV20 would just be rm, not rmvb.
Real do provide a free commandline encoder, it is called helix producer and will let you encode the video as RV9 EHQ (aka Real Video 10) and the audio as aac. Supports input via direct show so it can handle just about anything.
Best RMVB to AVI Converter
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 19:22 -
RMVB to AVI using VirtualDubMod
By mahdlo in forum Video ConversionReplies: 3Last Post: 25th Oct 2009, 00:36 -
rmvb to avi using virtualdub?
By kehn in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 09:05 -
help with rmvb to avi?
By fruitpassion in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 17:46 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 17:41
