Has anyone been able to play multisession DVD R discs on the DVP642? I've only tried DVD-R, and the player will only read the first session. Being able to play all sessions would be helpful, since I rarely get 4 gigs of video at once, and I usually burn things in 1-2 gig batches. Thanks for any help.
I do this on a LiteOn 2005 using DVD+RW media. DVD+RW media doesn't need to be finalized so if your player reads +RW media, I suspect this will work for you - It's worth a try.
Hi
It's not just the Philips DVP642. Many standalone DVD players do not play multi-session DVD-R. I use Nero to burn all my DVD (data & video), whenever I burn a multi-session discs, Nero will give a warning that the disc may not be played properly by a DVD player.
Either you will have to wait until you have +4GB to burn your disc or to take a chance with another software/hardware. -
Use a DVD+RW or -RW to burn your video files. I am using DVP642 too, it do support multisession DVD+RW/-RW disc, I did for many times.
How to make USB video work on Philips LED series 6000 TV
By Joaquim Brasil in forum User guidesReplies: 3Last Post: 14th Sep 2013, 15:58 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 05:33 -
Philips DVP642 having trouble with X16 discs
By CaspianCanuck in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Aug 2007, 09:49 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 15:06
