Where is noise reduction option in CCE SP?
I looked and cannot find that option.
Which program has good noise reduction filter(exepct Tmpgenc plus).
Because when i capture with Canopus 110 i have many noise and need some program which has good noise reduction filter.
best regard
I use VirtualDub Mod with the addition of the Panasonic DV Codec for Filtering DV. Then I frameserve the edited or filtered video directly to the encoder, TMPGEnc in my case.
VDM has many available filters. AVIsynth is probably a better choice for filtering and frameserving, but has a steeper learning curve.
Filters for both can be found at http://neuron2.net/
While in VDM, after editing, you can also save out the audio as a WAV and use ffmpeggui to convert it to AC3, then combine it with the video when you author to DVD. -
I wrote a guide on how to use AviSynth and the Convolution3D video noise filter. It works very well.
Here is a link to that guide ---> CLICK HERE
Good Luck
Yes CCE has internal noise filters, two of them actually. Look on the picture quality tab. The low filter is your basic noise reduction filter. It is a low pass filter which blurs information to remove noise. Additionally, the Vertical filter is used to remove speckle noise. Read the manual for information on how to set these manually or use one of the simple settings up at the top.
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 22:14 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 12:18 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 10:43 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 20:22
