  1. I want to add these 2 dvds to one disk since the dvd was in 2 parts. Is there an easy way of doing this? I don't mind creating a main menu that only has 2 buttons for Disk 1 and Disk 2 if thats an option. Usually don't reauthor stuff like that so any help is appreciated.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There are guides in the How To section.
    Google is your Friend
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    DVDRemake if you want to keep the menus for both discs. TMPGEnc DVD Author and/or DVDShrink with a little bit of manipulation if you're happy creating your own menus.
    If in doubt, Google it.
  4. Originally Posted by |Supreme|
    DvdReMake will create a default start-up menu to select which disk to play for you. It can be customized (need Pro version for this): http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php
    http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
    Feb 2004
    WI.
    Yeah just use DVDShrink or whatever other program you use to rip movies and rip both disks movie onlly. Then Just add them into TMPGEnc DVD Author as Seperate tracks. Then you can create a menu to choose between the two.
