My actual capture card doesn't encode in mpeg2 format, and I've to use WinDVR3 to capture in real-time in mpeg2 format, but using the software recourses.
When my new card arrives (PVR 150), If I've to use WinDVR, the system knows that encode process will occur in the card not in the computer processor ?
Do you understand me?
I use it with GB-PVR, and the hardware is doing the encoding, yes. I don't think there's any way to get video out of the Hauppage 1/2/350 cards without using the built in hardware encoding.Originally Posted by roglopes
GB-PVR can be set to encode the captures to AVI (using sioftware encoding) when they have finished too, should you ever want AVI format.
/Mats -
You are correct, the PVR150 will do the encoding and not your cpu.Originally Posted by roglopes
I suggest that you first get everything working using WinTV2000 and then you can try some of the other programs like GB-PVR or BeyondTV. I say this because WinTV2000 is easier to setup than GB-PVR. Later when have a good feel for how things are working then try the other apps.
GB-PVR is a pain in the as... for getting a TV guide... it is not very user friendly in that aspect.bits
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2010, 23:32 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 19:51 -
WinTV Hardware Encoder Workflow?
By Armandoban in forum Authoring (DVD)Replies: 5Last Post: 23rd Sep 2008, 13:42 -
Best hardware mpeg2 encoder (under 700 $)?
By Speed Demon in forum Capturing and VCRReplies: 27Last Post: 6th Sep 2007, 10:01 -
Turbo.264 USB Stick Hardware Encoder
By willrob in forum MacReplies: 12Last Post: 25th Jun 2007, 23:58
